The Park Tool crib sheet gives up to 68Nm for some models, so is 40 really so high?40Nm is loads, don't do it that tight as you'll be bouncing up and down to undo it.
Bloody nit-pickers...You mean lightly greased?
Yes, but that's what it says on the cartridge box. Big difference between the bit your hands twist and the one you stomp on all the time.I have never used a torque wrench, but even 5 is quite high on a stem. I do it by feel, and 40 is very tight. I've been maintaining bikes for over 30 years. 40Nm is a lot.
I hope no one is going to falsely claim over torqued bottom brackets are responsible for 88% of injuries and demand legislation! I'm happy to leave people with BBs rattling if they like them like that...This getting to be like The Helmet Thread.
Needed an adapter too, so here you go, a bit of extra info.Bills tool store pat , bain st , nr The Barras for the socket
No half! Never knew this topic was so controversial! Hope this thread doesn't get locked before I can post my results tomorrowThis getting to be like The Helmet Thread.
Linky no worky, but like you I have found my torque wrench unnecessary for most stuff, and don't ever seem to have the right sockets or adapters to hand when needed. On the other hand one of my favourite widgets is this preset torque key with a 4mm bit, which I use for fannying about with headsets and stem bolts.Ok I have played much with my torque wrenches
Verdict:
The high value one, you were all right, is a waste of time on an ordinary (not carbon) bike.
I did the cassette up at 40Nm, it was tighter than when I did it by feel (3 clicks more from the cassette) but it was riding the same.
Btw, I was able to undo both the torqued cassette and the non torqued one with no issues, maybe because I did lightly grease the freehub, or maybe because I'm just
I don't think I will bother using it again next time I do cassette, but I will for cranks, just to get the feel of the difference.
The small value torque wrench tough is a great bit of kit: I discovered that I have a tendency to over-tighten the wee bolts, I will use this tool all the time now.
Again, thank you all for the responses, here is a link to my fettling.
