Torque advise please
I've got a chorus ultra-torque crank that needs 42nm. However I do not have time to go to the lbs to get it done at the moment. What sort of force does this crankset require in terms of guess it force?
Thanks
Mr Pig
That's about 30lb, which isn't that much. To put that in perspective most alloy wheel nuts, on cars, tighten to around 80lb so you want about half that.
A car torque wrench should go down to 30lb, can you get your hands on one of those? a neighbor maybe?
hubgearfreak
you don't need to guess what's 42nm. it is 42 newtons per meter.
extend your sliding t bar (pictured) on the correct socket to a meter in length. apply 42 newtons to the end. job done.
here's a clue....4.3kgs at earth's gravity would give you 42 newtons
hubgearfreak
spandex, you're applying much more than 42 newtons to your arse.:biggrin:
i look forward to maybe a pint (or two) at the end of june?:ohmy:
i look forward to maybe a pint (or two) at the end of june?:smile:
I am up for that but I do not know if the same pub will be open this time as it was flooded and they do not seem to be in a rush to open:wacko: but there is loads more:biggrin:
ER just two? did you get told off last time?:wacko:
MichaelM
Tayside
Nah - 42 nm is 42 nano metres. 42 N m is 42 Newton Meters.
There's a difference!!!
Personally, I use the "aye that feels about right " method.
jimboalee
Solihull
Gravity's acceleration is 9.81 m/s^2.
Divide 1 kg by 9.81 and you get the weight of a small apple.
"What was that hit my head??" A Macbook Issac.
Tynan
e4
hang 4.2Kg off a metre of wrench is the poster's advice, a coupe of bags of sugar and perhaps some rice init?
arallsopp
Post of The Year 2009 winner
Bromley, Kent
Ouch Aperitif! That one hurt :biggrin:
OP: If you're blagging a torque wrench, be advised it might have some arcane imperial measures on it. There's a handy converter here.
Of course, the site will also tell you that the force required is equivalent to 10 international calories. That's roughly one and a half Cadbury's mini eggs, so pop down the shops now and get eating then burn it off :wacko:
hubgearfreak
There's a difference!!!.
you're right, there's a difference. but most people would take the reply as given and not be quite so pedantic:biggrin:
