They had to use Seccotine.What, no cable ties and WD40. Sheesh !![]()
You've heard of the seven ages of man, right?[shakes head before dropping it into hands]... you are a grown up, right?![]()
.Not true.I found out this week that super glue was invented to glue wounds back together on the battlefield in the Vietnam war (lots of people probably know this already but it was new to me)
Which explains why it is so good at gluing your skin and rubbish at gluing anything else
They are not intended as PPE. Their use is to offer a minor reduction in the chances of the wearer passing on the infection to others. If you think wearing one offers you protection you're deluded.So masks are one of the main methods of protection.
Not true. Superglue was invented by practical jokers to stick bums to toilet seats.
Yes, but not over the face - it's been glued in the correct position for its primary function as a chin hammockIs the mask now permanently glued on?
How big a mast, and what material(s)?Tried polystyrene cement but it's no Spitfire. What can you use to fix a broken mask if you dont have a spare
Been drinking again?Top tip of not to do with face masks
Wear them in the first place.
You shouldn't need to repair a face mask as they are only truly effective if used once and then binned. ** I feel once could be stretched to a full day but certainly not used the following day.Tried polystyrene cement but it's no Spitfire. What can you use to fix a broken mask if you dont have a spare
Mine hadn't been used when it broke - straight out of package. I either fix it (which I did) or put a huge amount of energy into getting my money back. I used glue that wasn't super but it did the job.You shouldn't need to repair a face mask as they are only truly effective if used once
