al-fresco
Growing older but not up...
- Shropshire
Being a short arse (5' 7") I find that the combination of a 50cm Surly Cross Check frame, 700 wheels and 170mm cranks means that if make a tight (ie U turn) my toe will foul the front wheel if I'm not careful. I removed the front mudguard which improved things but it still happens occasionally.
I reckon 165mm cranks would probably eliminate the problem altogether.
So my question is - have you experienced the same problem and did you solve it or just learn to live with it?
