... The pressures given on the tyre wall are max pressures. The shop mounted them and inflated them to (surprise, surprise) 50psi: didn't need to say a 'word'.
I agree that the shop didn't
need to tell me, but it was the decent thing to do. Of course they got another $20 from me for a new tube after the blow-out, but they also reaped some ill will. Next time I'll go to a different shop.
It seems like most people here are aware of the pressure issue but I don't know how non-experts are supposed to know, especially when there's so much misinformation from apparently expert sources. For example, these websites:
www.sixthreezero.com:
How Much Air Should Be in My Bike Tires?
The recommended air pressure is written on the side of your tires in embossed lettering. Simply fill your tires with a pump and check with a gauge that the pressure matches the recommended range.
www.theproscloset.com
Conveniently, every bike tire has recommended PSI stamped into the rubber on the sidewall.
Here are some more specific recommended starting points for your tires:
Mountain bike tires: 25 PSI
Gravel bike tires: 40 PSI
Road bike tires: 90 PSI
https://communitycyclingcenter.org
Decoding all those numbers: If you look closely at the side wall of the tire you’re likely to find a few sets of numbers embossed in the rubber, but what do they mean?
Recommended minimum and maximum tire pressure: Skinny, road racing tires might range from 90-130psi.
Note that they all say that the psi stamped on the tire is the recommended pressure, NOT the maximum pressure. My recent blow-out proved to me that's incorrect, but how was supposed to know that unless the shop had told me?
It is 'safe' to run them at 50psi.
Thanks, that's what I'll do.
