Slick
Wow, how sad was reading that story. Obviously you would never know how you would react unless it happened to you, but I suspect this guy is a much better man than I am.
She had done everything to be visible.Wow, how sad was reading that story. Obviously you would never know how you would react unless it happened to you, but I suspect this guy is a much better man than I am.
https://www.cyclechat.net/threads/s...-cyclist-left-unable-to-speak-or-walk.218116/
I didn't read the entire thread, but I can't believe that is what you get for such an offence. Really disgusting.She had done everything to be visible.
They do, mind you I must be the only skeleton with a beer-gut.And the last post from that thread is worth repeating on this one.
One of those 'skeleton' tops might have similar 'attention grab'.
It's raining (down here in Devon) otherwise I would be out cycling. On the plus side the forecast is good (sunny if a bit 'fresh') for tomorrow and Wednesday.
Do you disagree with the view that one needs to prove hi viz is not effective for cyclists?
Don't you think that if there were data to prove hi viz is effective for cyclists that this would be easy to find? Think of the commercial benefit to the hi-viz industry.
I'd suggest that the reason why industry uses hi-viz clothing is not for 'operational' reasons but to mitigate the risk/effect of litigation, rather than because its use has proved to offer a 'real' benefit (reduction of accidents). This is the basis of their 'business case': they are not spending money "for the sake of it". In the Risk Management 'bow-tie' this is dealing with the consequence of the 'event' rather than minimising the risk of such an event happening - a measure of interest to a company concerned with the effect on reputation (however unfounded) and litigation. The 'consequence' issue is the reason (warning - off topic - please do not pursue - for illustration only) I wear a h****t: because I don't want my BH and others to say/think (after the event) 'if only'?
In an industrial setting where items may fall from height (eg oil rigs, refineries ime) or where height in passages is restricted it makes sense to mandate the use of a hard hat: good research has shown that the protection such a head cover offers reduces the damage to the worker wearing it.
Follow it further: will they lose ££££s because hi viz works or merely because enough people are convinced it works that they risk losing court cases if they don't have due regard to that view?Following this through I suggest industry is sufficiently convinced there is a benefit to wearing hi viz which is literally too expensive to ignore. The balance is simple will a company spend more on hi viz than it will lose in compensation ££££s? That is what drives the decision.
Thanks but that's not it. It was a description of the different colours suited to the many different backgrounds and lighting situations that showed that any one colour of hi-vis jacket would be ineffective most of the time.
https://www.ncbi.nlm.nih.gov/pubmed/22062342 "Attention and search conspicuity of motorcycles as a function of their visual context"Thanks but that's not it. It was a description of the different colours suited to the many different backgrounds and lighting situations that showed that any one colour of hi-vis jacket would be ineffective most of the time.
