Smart trainer for bad weather, if it's ok then I'm out.So its not Grangemouth in Scotland? In the Wet season, January to February next, I'd go stir crazy across the Forth for me there was a definite need to get out when I didn't commute![]()
Enjoy your once a year morning outSmart trainer for bad weather, if it's ok then I'm out.
A typical dishwash contains 0.2% sodium chloride. Shampoos and shower gels about 2.5%.Google reckons around 5%. Not a lot in a couple of drops then?
What is this washing dishes of which you speak...I have a machine to do thatA typical dishwash contains 0.2% sodium chloride. Shampoos and shower gels about 2.5%.
It's more than sufficient to use a cloth to clean the bike.I’m not sure what the weather is like where all of you live, but where I live it has been raining on and off for the last few days. My bike is getting fixed next week and I want to go out when the weather is nice (who does not?), but there is a chance I may get caught out in rain.
Once I get home, is it sufficient enough to use a towel, cloth, or whatever, and give the bike a quick clean/dry?
How do I avoid the pedals becoming seized? Do I spray WD40 or something similar on the pedals every now and then?
Similarly, do I use WD40 on the chain after every other ride?
I want to avoid getting any rust on any of the parts on the bike and keep it in good condition.
Sincere apologies if you thought it rude.The OP asked for advice; I gave it.
The statement that "the salt thing is absolute bollocks" is uninformed and rude.
While writing my response I did come up with a "working hypothesis" (sorry can't help it, the way my mind works and years of training/experience in the chemical industry):
metalwork is protected by paint and wax/grease from previous cleanswashing up liquid has SLS (mighty fine surfactant) which strips any wax/grease from paintwork
Any scratches/bare metal are now open to "attack" by salt in the weak solutionchemical reactions can be fastany damage now done/started before any rinsing (if you do it)
possibly over the top on my part, but it is my advice and I see no reason to use washing up liquid when there are so many formulations available for washing and waxing cars at low cost.
Ok.I’m not sure what the weather is like where all of you live, but where I live it has been raining on and off for the last few days. My bike is getting fixed next week and I want to go out when the weather is nice (who does not?), but there is a chance I may get caught out in rain.
My understanding is not causing corrosion, it does dull shiny paint so not recommended for that reasonGood input. However, is the presence of sodium chloride actually going to corrode anything when used at the very low dosages that would be present in a foamy water solution? One which is applied and then almost immediately rinsed off? One that also contains a number of surfactant species?
So to summarise - It's a bike; they don't need much looking after. Keep it clean if you want, but if you don't it just means it won't look so attractive to thieves - and worst case scenario means some components will wear out more quickly, but they are all replaceable anyway (and no matter how anal you are, they will still wear out eventually if you put in the miles). A bike is for riding; not an ornament!
EDIT: To answer your real question, though, it won't ruin your paint work, but will leave it dull and lifeless. You will have to rewax every time if you expect it to look good and stay protected. I'm not sure why you'd want to do this when you can just use car wash instead and not have to worry about the wax every time you wash your vehicle?While the detergents in dish soap do a great job cleaning the car ... they also remove much more than just the dirt from the surface. The detergents break down the wax, stripping it away and leaving your paint dull and unprotected.
Good car wash soap will not contain any detergents and will be rich in lubricants (which safely lubricate the dirt, allowing it to glide from the vehicles paint). A “feel test” you can use to test your car wash is to put a small amount of it between your finger and thumb and rub it back and forth. You will notice that better car washes will be much more slippery. Lesser ones may contain detergents to “help” clean the car (since the lubricants aren’t there), so make sure you check that before buying.
