SquareDaff
- Doncaster, South Yorkshire
It would make a huge difference - You'd probably be able to get up to 17mph from 14 without increasing cadence or rear selection.l would put it on the big chainring at the front but when l select it all it does is try to jump onto the ring so l left it on the middle front ring.
Would or does it make a difference to speed if you get on the large front ring...
Onto the ring? Do you mean it doesn't engage on the outer (big) ring or it jumps beyond it. If the former you need to adjust the cable tension on your shifter (probably) so that the cable pulls the front arm across a little further (basically it's not travelling far enough to move the chain at the moment). If the latter - you need to alter the adjustment screws on your front arm so that it doesn't throw the chain off!!
