- South Manchester
jimboalee said:I have slowly descended steep hills ( Winnats pass ) many times with the brakes ON for the duration.![]()
You do about 40mph down Winnats WITH the brakes on
1st. Helps if you know the road, junctions/hazards etc - including where cross winds are (more later).
2nd. Don't death grip the bars - you need to be fluid.
3rd. Look through and past bends
4th Side winds - at high speed these can be an issue, especially on exposed sections - got buffeted at 55mph coming down Woodhead last Winter - caused a slight speed wobble, which I corrected, then hit top speed again.
5th Helps if you've got a bike designed for high speed - doesn't feel like you are moving.
6th Last of All - Don't descend faster than your ability - if you don't do high speeds often, take it easy.
