phil_hg_uk
I am not a member, I am a free man !!!!!!
Climb some hills then when you have done that climb some more hills and repeat ............... after a while you will be able to go up said hills in a higher gear and you will be fitter
Start doing some running,dont just concentrate on improving fitness on your bike,its a long drawn out process losing weight simply cycling unless you are doing miles of hills everyday
You will immedietley gauge your real fitness when you try and run up the road which cycling can never do,i doubt many cyclists could manage even a couple of miles jogging without becoming completely knackered,the strength you gain through a running regime coupled with hill climbing on your bike gives you a holistic fitness and is far better than just solely cycling
Try and do a few miles running a week to complement your cycling,running is way more effective in losing weight than cycling and as the weight drops off your hill climbing will improve
Do you have many steep climbs near Luton!All of the above. Plus if you've got a triple, change it for a compact or avoid using the granny gear.
I'm a sprinter, and I've found that I've become slower since starting cycling, think I'm improving fitness, but losing strength/ fast twitch muscle!This is true, I'm a runner first and a cyclist second, I have found since I have been on the bike my running is quicker, they defiantly compliment each other.
I'm an all rounder with a sprint finish. I've noticed running helps my cycling but not the other way around. Long rides really take the turn over out of my legs even if I'm feeling good.I'm a sprinter, and I've found that I've become slower since starting cycling, think I'm improving fitness, but losing strength/ fast twitch muscle!![]()
Had to take some of my daughter's Spanish friends back to Luton Airport last week, Terrain seemed to be like a lot like High Wycombe to me, so possibly yes. Chalk downland you see. Usually convex in profile so very steep at bottom getting more gentle towards top. A good example is the Windmill climb out of Fingest in the Hambleden valley"What doesn't kill me, makes me stronger!"
Load of old b*llocks that - my last forum ride to Otley nearly killed me, and I haven't been strong since!
Do you have many steep climbs near Luton!![]()
The Horsehold climb at the bottom of the map is a road to nowhere. Well, it goes to the Hamlet of Horsehold, and on to a few cottages and farms, but then you have to turn round and come back down unless you are on a mountain bike. TBH, I don't think I have ever done it on a road bike, and it is many years since I did it on my MTB. I'll give it another go when I am well enough.Which is your favourite ?
