tightening bolts/seat clamps on carbon frames.
It should say on the clamp. IIRC it's usually about 5 or 6 Nm.
If in doubt get a torque wrench or a Ritchey torque key, they are pre-set to 5Nm.
jack smith
Durham
can i just butt in here, are torque wrenches really neccacery? i mean is there any major difference between a set torque and as tight as it will go? i get the feeling it is incase something breaks but what about solid parts such as heavy duty metal stems?
AndyRM
XOXO
North Shields
Finger tight, then a bit more is what I've always applied.
If you reach b&stard tight, then you've gone too far.
Hacienda71
Or you can pinch a bit of hairspray of swmbo. :thumbsup:
martint235
Dog on a bike
Welling
After crushing a carbon seat post I can definitely say there's a difference. Carbon, iirc, is usually woven to provide a particular directional strength so can be damaged if pressure is applied in the "wrong" direction.
That said I don't use a torque wrench but I also don't own any carbon anymore! :tongue:
jack smith
Durham
Cheers all! Got a lot of carbon on the way inc bars stem seatpost and saddle and think I'll get a torque wrench before they arrive lol
screenman
Seems to work well on seatposts. I have used it on mine and never had any slippage since.
My worry would be not getting it out again. I only questioned it because I had never heard of it before, are you not concerned what effect the solvents may have on the carbon.
BlueDog
Somerset
Are there any special considerations to be given when tightening up parts on a carbon frame such as the seat post, is there a need to be a little more careful or will it take the same pressures?
Hi Salty seadog - I'm guessing that this question is in advance of you getting your Corbin framed Whyte Montpellier... After owning mine for about 2 months I started to get a knocking sound from the back, which I ignored for a while, but then found that the 2 bolts which hold the disc brake to the frame had come loose (very loose actually!) and the front disk block was also quite wobbly. I can only assume that the LBS didn't do a particularly good job in checking these before handing it over to me. Anyway, I then got a torque wrench as a present, so I'm now better safe than sorry:thumbsup:
