andrew_s
- Gloucester
If a tyre won't go on without a real struggle even when using a carryable tool such as the tyrekey or Var lever, it's going to be equally difficult, if not more so, when out on the road.
What I did when faced with a similar undersized tyre was to put it on a spare wheel (which must have been slightly smaller), pump it up to 160 psi, and leave it stretching until the alternative tyre I fitted instead had worn out. By that time it was OK - "normal tight".
