Tight spoke nipples on new wheels. Tips - before I break a spoke?
Jon George
Mamil and couldn't care less
Suffolk an' Good
I'm a couple of weeks into a new Fulcrum 5 wheelset, and after putting some miles into them, the rear wheel is very slightly out of true. I went to adjust the offending bladed spoke, but it twisted in sympathy with the nipple. As the wheels are new, I can't imagine that they'd need oiling to loosen, but I think I need help/advice before I go for trying to break the 'stickiness' by either over tightening/loosening beyond what is needed to cure the alignment and risk maybe breaking a spoke. A squirt of WD40? How much 'twist' can a bladed spoke take, anyway?
They will probably have a touch of lock thread on the them done in the factory
Try loosening the offending spoke/s by a quarter turn ..
Personally I would give it to a good wheel building LBS
Let them do it !
raleighnut
I agree with tissot and would also add that any reputable LBS would service new wheels after a couple of weeks as part of the sale.
What would you suggest? I have bladed spokes and used a pair of pliers with some kitchen towel in the teeth last time.
That works, but I am sure Mavic do a tool. I do the same as you, and hold the spoke in place with needle nose pliers and a rag. Just stops the spoke twisting
As above.
Make sure you are turning the correct way and that the spoke key is properly seated (to prevent rounding the edges) then put a lot of force into it.
There will be a loud crack as though the rim has broken but it will just be the nipple freeing itself from the threadlock.
Jon George
Jon George
Suffolk an' Good
This was the solution I decided on - I used a spare rubber insert meant for a rear light fitting, rather than kitchen towel. I also used the correct tool my LBS provided free of charge for a different set of Fulcrums I purchased from them (this set came from Ribble), but it looks like I'll need two (it appears to be both a spoke key and blade-spoke holder) if I want to dispense with the pliers in future.
BTW Wheels now running sweet. ^_^ Thanks again, peeps.
srw
It's a bit more complicated than that...
If a pair of £200 factory-built wheels have gone out of true after only two weeks, they're duds.`Return them.
Jon George
Jon George
Suffolk an' Good
If they were more out of true than they were, I'd be considering this (or if I'd spent more than the £158 I did), but I've been giving them some pretty brutal treatment (in my eyes, at least) and a less than1/8th adjustment on one spoke far outways the hassle of doing so. If, however, the situation worsens, then I'll be getting in contact with Ribble. :smile:
