Has anyone else had issues with Shimano front derailleurs, specifically Tiagra 4700? I had it changed at LBS last year, to cut a very very long story short, after fiddling with it for hours (limit screws, cable tension etc) I couldn't get it to stop rubbing in the 2 largest cogs at the rear and the smallest cog at the front (I run 50/34 at the front). Eventually I realised that when I changed down I could push the derailleur back with my fingers another few mm which stopped it rubbing. The LBS said it was corroded, given it had done 3 winters I thought "fair enough" and had it replaced. Now the new one has done the same thing (2,500 miles and 1 year)!!! I guess I can kind of put up with it as I only notice it when climbing, but as most cyclists know any unwanted noise gets on your nerves!
Has anyone had similar issues, and how did you solve them?
Thanks, Paul.
Thanks, Paul.
