Does anyone know how to easily remove this Through Hub and the associated Freehub Body please?
I have a standard Shimano Lock Ring tool (not a copy from another manufacturer); no issue removing the cassette, however the tool is not long enough (deep enough) to lock onto the disc brake rotor lock ring on the other side because the hub protrudes too much!
Watched various videos through You Tube. Not one appears to show my hub configuration. The hub has NO visible Allen Key socket anywhere. Flats only on the drive side, and the non-drive side does not pull off (bearing in mind the brake disc is still on the non-drive side).
I'm somewhat perplexed!
