youngoldbloke
Standard motorcycle size, 9" X 7".
If you put it through a test to get it classified as a motorcycle, albeit electric powered, what do you expect?
I won't be buying one. If I needed such a machine I'd simply buy a moped and consider my cycling days overIf you put it through a test to get it classified as a motorcycle, albeit electric powered, what do you expect?
Characters may be small as 44mm wide x 64mm high, but the number of characters on the plate determine the final plate size.
.Having seen an electric motorcycle, and getting to know the person riding it, I'd be more inclined to go for motorcycle than moped.I won't be buying one. If I needed such a machine I'd simply buy a moped and consider my cycling days over.
I understand that Wisper ebikes are fitting a throttle to there new ebikes .That will reach 15 and half miles per hour ,hope all makes follow suit.
I not in films but think there are a few cowboys around.Well, they aren't legal to use in UK and Europe. PS messengers usually get shot in films !![]()
If it's got pedals it's a bike MingNot in Europe and UK they won’t. If you want an emoped go for it, just don’t call it a bike.
And if it passes the MVSA, it's then legally classed as a motorcycle.I not in films but think there are a few cowboys around.
I had one of these when I was 16. It's a bike though, right?If it's got pedals it's a bike Ming
Like to see you get that up a hill without the motor!!!I had one of these when I was 16. It's a bike though, right?
Simple, get off and push.Like to see you get that up a hill without the motor!!!
It had a clutch that would decouple the engine and allow you to pedal it like a bicycle. It was not designed for pedalling!Like to see you get that up a hill without the motor!!!
No it's got a engine and can go much faster than 15and half mph .I had one of these when I was 16. It's a bike though, right?
Mopeds haven't had pedals for about 40 years. Even when they did, some of them you could fold the pedals out of the way coz they were pointless.A Gokart has pedals, a moped has pedals. In the case of a moped, the clue is in the name.
