thread repairs
bunnym0b
Regular
I've done the mechanical refresh up to a point> New cables, Campagnolo gear shifter, front derealieur, crankset peddles bottom bracket (and dust cover) it's all good and will have some new (to me) wheels (Period 5 gears French made). A new chain is on order. However there is a problem with the rear dropout. The threads are stripped so that the Italian threaded Campagnolo derailleur wont stay fixed. The sun tour was reverse mounted with a bolt running through the pivot bolt-thats not an option at the moment as i have the most useless item to affix... more later.
So I'm looking for someone in London who will undertake the repair. Condor says no, so does my local bike shop. It would be done in conjunction with a respray. Can anyone in London or beyond give me a steer for the repair and a respray/powder coat?
552052
raleighnut
Does it go through far enough to get a thin nut on the back,
rogerzilla
You need an M10 x 1 Helicoil insert, if one short enough is made. Any decent garage should be able to do it.
Profpointy
Is there enough meat on the derailleur to drill the (presumably unthreaded) clearance hole the next size up? If so you could drill and re-tap the dropout the next size up. Assuming I've understood the problem / which bit is stripped
bunnym0b
bunnym0b
Regular
I wonder whether going down this line might be an option. You'd be drilling and tapping a 'full thickness of fresh metal before respray.
https://www.ebay.co.uk/i/141021947534?
I have not attempted this and the image and link is not a recommendation, it's to illustrate the idea.
ive looked at this as an option and may do it. ive also sourced a set of dropouts which could be welded in. At some point however the cost begins to become an issue-its a Sprint, albeit one that fits me, and is in otherwise reasonable shape.
Ajax Bay
East Devon
an elegant solution
Without wishing to 'diss' that 'elegant' option unreasonably, I fear that the number of threads you'd get engaged would not be enough to keep the RD stable even if it was sufficiently secure and, as @screenman irregularly reminds us, vertical/unchanging rear mech alignment is essential for its effective function. There's a fair bit of leverage on an RD.
raleighnut
If you look at the dropout there ain't a whole thickness of metal on that either.
Ajax Bay
East Devon
1/4"? Surprised that the RD bolt will have enough showing the other side to get even a cone locknut on. But worth trying, easy to try and you've lost nothing.
