I didn't buy a T-Line because unfortunately, somewhat obviously I don't have over four thousand pounds to spend on a bicycle
not many do, and if I did have a spare £4000 to spunk on a bike it wouldn’t be a Brompton.
Likewise.. you do understand that liking something and being critical of it don't have to be mutually exclusive?I simply do not get why you are so upset.
No need; I've expended all the energy I'm prepared to on this drama..get the popcorn in guys
I have the crankset I took off mine before fitting the hope one if anyone wants to make an offer
I am really wondering how this is possible and why everyone in this thread seems to blame Brompton for this. Even the article on wikipedia about material fatigue is illustrated with a broken bicycle crank:Well my first impression on seeing the break was that it was a poor design! As fossyant said I've not come across one before.
As said before: It is not only Brompton that recommend exchange intervals for aluminium parts and not only cranks are affected but also bars and other aluminium parts. It is common thourhgout the bike industry and the cause is simply because of the properties of aluminium parts. Finger pointing on Brompton is thus simply a sure sign of ignorance and lack of knowledge on your side. It is obvious if you look once more at wikipedia, this time on the article about fatigue limits. Recognize the red line for Aluminium and the blue line for steel in the graph:If it is Brompton who are recommending the cranks should be changed every 5,000 miles it would make me question why? If it is them then they must know of other failures and why haven't they changed to a different crank or manufacturer?
If it was caused by fatigue due to loading why don't they fit a smaller chainring or is that because of wheel size?
If I had a Brompton I would looking for an alternative make of crank .
https://en.wikipedia.org/wiki/Fatigue_(material)
So this can really considered to be common knowledge and clearly not a problem of Brompton.
https://en.wikipedia.org/wiki/Fatigue_limit
There are tests for crank fatigue in ISO 4210 (on the norms that apply to bikes and are mandantory to pass to be allowed to sell them within the EU):
There has been lots of research about the topic, i.e. this:
• Fatigue failure analysis of bike crank arm using solidworks simulation (alternative version here and here)
• Comparative analysis between aluminium and steel based bicycle crank using numerical simulation
• Validation and Improvement of a Bicycle Crank Arm Based in Numerical Simulation and Uncertainty Quantification
• Influence of anodized depth on fatigue life for bicycle cranks
There are also articels about the topic like i.e. this:
https://velo.outsideonline.com/road/road-racing/technical-faq-aluminum-frame-crankarm-fatigue/ including this image:
Of course you are free to ignore all this real world evidence, mechanical basics and scientific research. Then (and probably only then) you may come to a conclusion like this:
It lacks foundation, but of course you are free to claim whatever you want to claim.![]()
I’ve never seen that before in all my sixty three years cycling.
I have heard of it on a very cheap bike. Still surprised me that it was possible.
Cheap cranks fitted on an expensive bike !
Have they gone as upmarket as hollowtech level cranksets yet?
I suspect the number of cranksets in use from Shimano is orders of magnitude higher than the million Bromptons you reference.
Ups! Today on road.cc
"Shimano finally recalls 11-speed road cranksets after more than 4,500 incidents
Shimano announces a voluntary inspection and replacement recall notice for 760,000 Dura-Ace and Ultegra bonded 11-Speed road cranksets.
After receiving over 4,500 incident reports Shimano has announced a voluntary recall of Hollowtech II road cranksets produced between 2012 and 2019 for a possible bonding separation issue. That includes two generations of the popular Ultegra and Dura-Ace cranksets."
https://road.cc/content/tech-news/shimano-11-speed-hollowtech-road-crankset-recall-304003
So less failed cranksets than Brompton frames...
