Deleted member 20519
Does anyone know how to change the default settings on the camera? If I press the record button it starts up and takes pictures, how do I change it so it starts up and records videos instead? Thanks.
I have also tried inserting foam, adding tape to the battery also reduces rattle in its cradle, drilling holes to reduce fogging etc.....but only with limited success. Yes light flare is quite high but I think the way the camera deals with low light I.E. turns a dark morning into what looks like midday compensates for this. I will try and take some photos of how I have adapted the case when I get five at the weekend. I also have mine on a RAM mount. I truly think my main problem is the state of the dressed roads around here as properly tarmac'd roads don't produce the rattle.
most of the roads on my commute are the same....I suspect Jazloc the camera gave much better footage from your lid? I have managed to reduce the rattling using some soft foam in the bottom of the case and also inside the cap.........the case has gaps on either side of the camera and I reckon that's where the rattle is created
mmmmm the speaker....this would explain a lot....will investigate....got to agree Rezillo....the footage straight from the camera via the Sony app is very good apart from oversaturated colour and flare......however compress it or put it on youtube and its crap, although I have got to admit I have not played with this aspect much at all. Overall i'm happy with what I want it to do.
I read in an Amazon review that one guy took the entire front door of of his camera and secured the camera in it's case using rubber bands. He said this eliminated lens flares and stopped the camera fogging up, he also said it gave him better audio. Thoughts?
