Andy in Germany
- Rottenburg am Neckar
Southbound trains towards Freiburg are running slowly, and about every five minutes.
Next train, so that's six minutes apart. It's like this most of the day.
Been reading E S Cox's memoirs (he was largely responsible for the BR Standard steam locos, as well as the Horwich Crab). He was obviously a really good engineer and, despite having a soft spot for steam, explains why it's so woefully inefficient. The boiler is, surprisingly, about 80% efficient at turning burned coal into steam. The problem is in the cylinders. The theoretical Rankine efficiency is only about 15% with typical locomotive temperatures and pressures, and most locomotives achieve quite a lot less than that because of sub-optimal valve events (wire-drawing etc). Add it all up and you get a dismal 5-10% overall. You can't increase boiler pressure beyond 300psi because the weight of the thicker shell and tubes becomes too much for the track.
Worse, the locomotive wastes a lot of fuel just sitting around keeping warm or heating up from cold, and dusty coal or a careless crew can mean lots of fuel literally goes up the chimney, unburnt.
You can see why we have diesels. Cox reckons there were no more technical gains possible with steam beyond the mid-20th century, apart from a few labour-saving tweaks.
Yes to both.Dud they ever build a steam powered turbine engine or a steam powered turbine / electric engine.....
The daily Sylt-Lörrach sleeper and car train has passed. As well as German, Swiss, and Austrian stock, it had a sleeper carriage from Swedish Railways. I really hope that's due to some common carriage pool arrangement and there aren't some people on board expecting to wake up in Stockholm in half an hour...
Andy, you're giving us all these tantalising descriptions but no photos. What's happening?
I agree, @Andy in Germany we deserve at least one picture... 👍
Oh, fer goodness' sake.
This isn't from work but a few kilometres outside of the town which is why it looks rather rural but it gives the idea, Also it shows that phone cameras and strong sunlight don't mix very well.
I haven't been linesiding for a while, I should probably go now while the trees are nicely autumnal.
There. I'll find/take a picture of the view out of the window next week; honestly, the things I do for you...
