The most likely explanation is that those signals are entirely spurious.
Looking at the data on the flight trackers, we are asked to believe that two stationary* objects occupy exactly the same position in the sky, one precisely 1,000 feet above the other. If, as suggested by some, they are balloons, how do they stop something that's on the end of 12 miles of wire from drifting around with changes in the wind?
* the two "objects" each actually send two alternating positions which are about 9 feet apart in a NW-SE direction, same every day:
https://flight-data.adsbexchange.com/map?icao=45FE5C&date=2019-09-07
https://flight-data.adsbexchange.com/map?icao=45FE5D&date=2019-09-07
(substitute any other date, and the "track" will be exactly the same)
Trust me, they aren't real.
