The dreaded creak - pedals, chainring bolt, crank?
beardedwarbler
Well, when I say creak, that doesn't quite do it justice. I've got a noticeable sensation of play in the cranks/pedals under heavy load, once per crank revolution, if I had to say at about 5 and 7 o'clock (viewed from driveside). Not so drastic as chain slipping, but unpleasant, and the sensation is definitely from the crank/pedal area.
I've installed a new BB and regreased and refitted to the correct torque just about everything on the bike. Relevant parts are:
- shimano A520 pedals (single-sided 2-bolt SPDs)
- SRAM rival 1 GXP crankset on threaded BB (I'll note the driveside arm is connected to the spider with a spline and torx bolts).
Everything seems tight on a workstand and I've not got a turbo trainer or spare pedals. I have a hill moderately nearby.
The only component that shows signs of wear, excluding SPD cleats, is the nondriveside arm (pic below), which I'm hoping it isn't as I can't imagine getting a replacement is easy. I wouldn't put a huge amount of confidence in the chainring bolts either, but they look fine externally.
Try loctite on the splines?
Change pedal tension?
New chainring bolts?
Or just dance a merry jig and pray to whatever deity seems appropriate?
iluvmybike
Have you serviced the pedals?
Jody
Stubborn git
For the benefit of future internet scrapers: I found the cause, it was the SPD/pedal interface, even with new cleats. For the time being am just living with regularly greasing them.
I have/had the same. Different SPD's and replaced the cleats.
Got fed up with it so went back to flats for a while
Jameshow
I have a similar creak on my Bb30 chainset. When I got home I found it wasn't torqued up very tight have I knacked it? I'll have to torque it up to 40 or whatever it's meant to be!
