The dark.......!
SamN01
Cambridge
I found myself out in the rain yesterday evening and for the first time on the stretch of road that leads from our village onto the A10, its only about half a mile but it is a twisty stretch of national speed limit road with no street lighting at all and no houses so no ambient light at all. To make matters worse there are large farms fields on both sides with light bush cover between them and the road. Not enough to stop the gale force winds from whipping across the fields but just enough to stop a car from seeing you until it comes around the bend at 60.
The truth is I was bricking it yesterday, I realised that my catseye lights might have enough light so that a car can see me however they provide no illumination of the road in the way that a car headlamp does. I thought they were half decent lights. What's the solution? All I can think of is buying more lights so that I have the power of two rather than one? I have a number of LED head torches that I use for night fishing, could I use on of those?
I have been deliberating upgrading my MTB to a flat bar road bike (Sirrus) or a Kona Dew Deluxe hybrid, when I left home yesterday morning I thought I had finally come to the decision that it was going to be the Sirrus however yesterday evening has left me a little worried that I could not see the road in some places let alone pot holes and perhaps for a commuter bike I may be better of going for the Kona or having a total rethink and perhaps opting for a cheapish commuter bike like a Carerra and then waiting until the spring before getting a road / better bike.:sad:
Search the forum for lights reviews. Words like Fenix, Ay-ups etc. etc. Rear lights - Smart 1/2 watt or Blackburn Mars 4.0's are very bright.
A headlamp would help.
Many folk are going down the rather bright LED torch routes if you are on a budget and want maximum light.
johnnyh
Somerset
I was in a similar situation, I bought two Fenix L2D Q5's and a couple of lockblocks, added a Smart 1/2 watt rear LED and now can see really well and am very pleased with my purchases.
At first I kept thinking it was quite an outlay, but then it is my life and safety and I would have spent the same on a tank and a half of petrol.
I've got the Smart 1/2 watt and Mars 4.0 and they are really good. Realising the nights were drawing in again but I didn't want to break the bank I went bought one of these Bspoke lights (a 1/2 watt set F&R actually). On its own it might not have been bright enough for dark country lanes but with it backed up by a EL410 helmet light I've got plenty of visibility (that ad is wrong BTW it takes 3 AAA's).
From this thread, it looks like one (or two) of those Tesco jobbies and a DIY mount using a bit of old inner tube is the way to go for £10 (or £20).
Had I not laid out on a pair of Cateye fronts a few months ago, I'd be doing what Steve said in that thread.
J4CKO
I have the Tesco lights but though they are bright, they dont last long and you cant make them flash (well I cant) so I have sent back my CatEye Singleshot plus (quite bright) as the brackets werent up to the job and disentegrated, have ordered a Hope Vision 2, expensive but I dont want to rely on just the torches.
Basically, the more light, the better.
Never just cycle with just one if you are doing any distance or could be stranded on unlit roads, always have a backup, Tesco do some Led ones for under three quid which I have attached to my jacket just in case, so with the two torches, the Hope Vision I should be ok. If your lights do conk out, stop and call someone to pick you up !
Might get a second rear, trouble with rears is you dont always notice when they stop.
wafflycat
Which Cateye light(s) you using?
SamN01
SamN01
Cambridge
Cats eyes
I am not sure what they are called. They are oblong with rounded ends and 3 LEDs in each. They are okay if you just want to be seen but they are not 'lights' they were only 20 odd quid for the set.
wafflycat
There's all sorts of Cateye lights - which range from 'be seen' to retina-searingly bright. The one's I use (2 x EL-530) give me enough light to clearly light up the road ahead as well as to be seen by oncoming motorists. Many a lighting manufacturer does a range of lights..
marinyork
Resting in suspended Animation
Logopolis
Sounds like the El-135. I have two EL-120s among other lights. If you use them in combination they are good to be seen but you'll never get enough out of them to see.
