I do like the idea of a brake light function. Anyone had experience of one?
Do they work? How do they work?
Thanks.Well the first one is probably not really quite bright enough. At 45 lumens max, it won't really stand out enough for daylight running.
While the second is maybe a little too much. Would certainly be too much for night time. The red light can be lower than the white, even in daylight, but I would think something in the 75-100 area would be best for both.
The brake lights work by use of an accelerometer in the light. How good they are, I have no idea.
OK, thanks.I have some experience of a different rear light with a brake light function. I have one and use it as my commuter light - it's quite neat in that if it senses no movement for a certain time it'll switch itself off and then come back on again when you move the bike. I have no idea how well the brake light function works other than holding it in my hand and seeing that it does work if I tip it one way then the other.
However, a riding buddy has the same light on his MTB which I see a lot of. I would say that whilst it does appear to work, it works too well, with any bump setting off the brake function, meaning it's rather meaningless as a brake light as you never know if he's braking or just hitting a bump, so he essentially has a random brightness light on the rear of his bike.
Thanks.
OK, I see your point, although I don't want to blind or annoy anyone so I thought the Krog Frog would just give an added layer of visibility, rather than being blindingly in your face, so to speak.
Thing is, I don't want a great big light on the bike, I don't need it, so any suggestions for something very small, sleek and compact yet bright enough for daytime running would be welcome.
OK, thanks.
So there are probably brake lights and brake lights, and not all will be equal I'm sure. I certainly don't want a random bump-o-meter light, so if that's what they are then I'd rather avoid the feature altogether.
Regarding the auto-off feature, so does it turn off after seconds or minutes? Imagine being at traffic lights or some other cause for stopping. You don't neccessarily want your lights to turn off... do you? Surely you still want to be seen, even when stationary, for as long as your actually sat on your bike anyways.
Another recommendation for the Planet X Dogstars as mentioned by @fossyant earlier. For £40 you can get two front & two rear lights that are probably bright enough for daytime use at the lowest setting. I have mine as the 'to be seen with' night time lights set up as below (the vertically positioned rear is normally on low flash)
Thanks guys, I'm trying to find something a little more discreet, at least for the ront light. Not the brightness, the actual body of the unit itself?
I haven't seen any of those pink/red swaying testicle rear lights yet this year. Anyone?
