scotsbikester
For me it's very very simple - I know me, I know how I work & I know what I do - I damage things.
I've broken things numerous times on the car through overtightening.
I've flooded the living room twice through overtightening.
I broke a mount for the Wahoo last week through overtightening.
There's a reason for it. I tighten it up and then (especially in the case of the radiator), I think that's probably not enough, I'll give it a bit more, then I think the same again, then I think what if it still works loose/leaks, I'll give it that 'just nip' that everyone loves to talk about.
*snap/bend/crack*
It's all well & good saying don't keep doing it up but what if what I've done isn't enough anyway.
So yeah, it's basically got to the point where if someone has put a torque setting on it then that's what I'll do it to, then I know it's right.
Even if the torque wrench is out a bit, it's still likely to be a better approach than MY 'just nip'
And thanks for the tip in the latter part of your post.
Yes, excellent self knowledge.
I'm the same. Unless I know what 30Nm "feels" like, how do I know when to stop? I don't always use a torque wrench. Until I got my beam wrench I had no way of torquing left hand threads. But at least I would have just done a right hand one on the opposite side (BB, pedal), so had a reference for "feel".
I've done all my own plumbing for several years now, including complete bathroom and kitchen refits, plus various rads. I have a dread of flooding the house, obviously, so avoid compression joints like the plague, if at all possible.
I've learnt a few lessons - 22mm copper is almost the same as old 3/4" imperial. That was a time when my perfectionism paid off. I wasn't 100% happy with a soldered joint I'd made, and a helpful chap at a plumbers merchant suggested - "it's not old 3/4" you're joining to is it? How old's the house?" That was a joint between kitchen ceiling and bathroom floor. I'm fairly sure it would have leaked/flooded eventually, but maybe only after the ceiling was up and plastered.
Compression joints? You just have to be patient, grasshopper. Tighten so it leaks very slightly. Tighten a bit more till it stops That's almost certainly enough. And on rads you can keep inspecting. It helps if you haven't got a floor covering that will get damaged by a small leak. Otherwise the old towels come into use.
Where compression joints scare me is on cold supply. CH isn't at very high pressure, but our mains pressure is 5 bar, and we've got "fast" taps - quarter turn or lever action in the kitchen. I tell the family not to turn cold off too quickly, but I'm not sure everybody (including me) remembers.
