TH 7700 BB upgrade....advice reqd....
stoatsngroats
South East
TH7700 bottom bracket removed.
It reads 68mm, and the crank length measures 110mm.
My question is, will any cartridge Bb fit, or should I be looking, perhaps measuring the flats on the taper?
Also, as I have Sora gear, will I need a Sora BB?
And, at Sheldon Brown, he shows the differing quality of BB HERE , and are the measurements 68x110mm available in each category?
Sorry for sounding thick - it's because I am :biggrin:
Any square taper BB with a 68mm shell and a 110mm axel will do. Usually a bit wiser to spend a little more.
I assume it's square taper then....
OK - any will do - just go of those 68/110.
Try and get a better cartridge bb, as you'll get the metal lock ring.... the plastic ones can be dodgy.....
stoatsngroats
stoatsngroats
South East
peanut said:
I presume that you have English threads in your bottom bracket ? if not you'll need an italian threaded BB .
Any square taper BB will do as previous posters have said, that includes Campagnolo ,Miche, mavic, Stronglight etc
this would do for example, it has steel cups
http://www.ribblecycles.co.uk/productdetail.asp?productcatalogue=STROBTBR300
Thanks peanut!
I'm certain the threads are British, I've got some vouchers for a LBS, and I'm getting a UN54 BB tomorrow. Hopefully, that'll solve my problem, and I'll be back on my bike Thursday!
I also used the last of the vouchers to grab a truflo micro Co2 inflator, Wowee....!:smile:
(not bad for £5's worth of raffle tickets eh...?):smile:
