I bought one of these torches (AA model) and I'm impressed. At first, my rechargeable batteries wouldn't fit so decided to get a round file (just under £5 from B&Q) and started filing out the barrel. Probably took less than an hour of elbow grease (not continuous I might add... just kept going back to it every now and again) and... hey presto, they now fit
I actually filed more than I needed to as I plan to get some higher capacity batteries, just in case they're even thicker than the ones I've already got.
Got it fitted to a spare Smart light bracket I had... the top plate unscrews which leaves a hollow for the torch to sit in. I drilled a couple of small holes in the side of the bracket and fed some cable ties in, then wrapped around the torch to secure. Works brilliantly afaic!
