Ian H said:Don't remove the nut. Just loosen it a couple of turns then hit it hard. If necessary loosen it again and hit. this prevents the end of the cotter pin mushrooming.
That used to be my method, protects the thread (somewhat) from distortion, helps prevent the threaded section from bending as its hit with a hammer. If that fails, virtually everything else would have anyway, perhaps barring heat.Don't remove the nut. Just loosen it a couple of turns then hit it hard. If necessary loosen it again and hit. this prevents the end of the cotter pin mushrooming.
