thom
____
- The Borough
That's kind of my point - to use it properly, you need to know and investigate more.You don't use it like that. You set trigger points and use the data to see if the trigger points are, well "triggered".
Once they are then you investigate a little deeper.
It's not dissimilar to what they have done in my field, albeit it's not there to catch cheaters per se.
What I worry about is if the data is public, people will look at it and try to make conclusions without really knowing enough or having the ability to investigate more deeply through other means.
