classic33
Leg End Member
Hope you didn't drop it on your toes.Pretty heavy, down from first floor . Then up to another first floor. Removing the far heavier old one right this minute...
The small bales are roughly that size.For the sake of complete accuracy l will measure one this afternoon (in real money) !!
You might have some "fun" with that.Hell, I do
not
Two computers running 32 bit and capable of running 64 bit so I tried one and somewhere it got into the 'Automatic repair Loop' so just used a DVD of x64 windows 10, new partition on the drive and voila..now running well and got most stuff up and running.
I'm debating this one I'm writing this on...
Only one very old program not running but I could get it running on compatibility mode if I want but I'm using a newer better alternative after a wee SQL problem
I may do this one at one point soon after this big Fall update due out today, apparently.
All going well...You might have some "fun" with that.
I 'inherit' computers...I hate the obsolescence of computers. I exclusively use or rebuild old desktops and laptops. Have two older slimline desktops, one my main pc, the other runs Netflix etc into the TV. Both W10x64. Wife's laptop, same. My laptop is an older AMD-based Toshiba, which because of the old Radeon chipset, can't be made to work with W10x64, so x86 it is. For now. I expect every major update to break it completely, but it's hangin' in there...
All going well...
Removing the old one turned out to be easier than anticipated. Thank the Flying Spaghetti Monster for large estate cars!Hope you didn't drop it on your toe
Aye...Still??
Thought you'd sold it elsewhere!Aye...
whizzing along...
selling my soul to Google helps..
Ok so l measured them.....like l haven't got much to do this evening! They are roughly 36"x20"x14" (photo below)28" X 16" X 12" or 710mm X 400mm X 300mm?
The second set of measurements(elbow-fingers x elbow-wrist) were fairly accurate then.Ok so l measured them.....like l haven't got much to do this evening! They are roughly 36"x20"x14" (photo below)
