172traindriver
Well it'll be Friday evening, and you'll be headed home unlike Monday when you'd have been going into work!
Good job the schools are shut
More on the streets though!Good job the schools are shut![]()
It's been to the LBS, 2 mins on their stand and a quick tweak and it's running fine again. Any further nonsense and it shall get a new cassette!Yeah, I replaced a chain on my winter bike and was running fine on the stand - as soon as I put pressure on the pedals it skipped like crazy. Would only work in the big ring. I'll wager that's what happened with @ScotiaLass too.
If you were just changing the chain you shouldn't need to touch the indexing unless something's seriously worn, once you had the new chain on did you try your gears before you went to adjust them?It's been to the LBS, 2 mins on their stand and a quick tweak and it's running fine again. Any further nonsense and it shall get a new cassette!
See New Threads on main page for the answer.If you were just changing the chain you shouldn't need to touch the indexing unless something's seriously worn, once you had the new chain on did you try your gears before you went to adjust them?
That will be 4 days by several different crews from several different stations in stints with time off in betweenFour days for the pro's in the final one there.
House's there now
Starting FIRES !!What doing?
Mr TD won't be happy with the Hoops winning the Title AGAIN !!Buzzing Mr Choo?
a BIG day tomorra
I actually watched the 2nd half of the Rangers / Motherwell game last night...
for my team I'd be glad to see Rangers stay down (for financial reasons of course)
The gears were a bit dodgy before, so I thought I'd set them while I was thereIf you were just changing the chain you shouldn't need to touch the indexing unless something's seriously worn, once you had the new chain on did you try your gears before you went to adjust them?
18 appliances at the height of the fire.That will be 4 days by several different crews from several different stations in stints with time off in between![]()
You've had rain!You'll be delighted to know (I'm sure) that I made it home safely without my phone - even managed to dodge the rain clouds, thunder and lightening!
