Tapatalk advert on top of iPad screen
Lee_M
I'm confused by your message Shaun. I've not even got tapatalk installed - so I assumed that was why I was getting the message
EltonFrog
EltonFrog
Same here, no TapaTalk, but I've still got that annoying message:
Here is a screen shot for my iPad.
Shaun
Founder
It is being generate from the Tapatalk add-on that is installed here, on the CC server - which is generating the prompt on your device browser. Once they fix it and I update the add-on on the CC server it should remove the notice.
It used to be a simple popup notification and when you clicked "Cancel" it went away and stopped pestering you, buy they've obviously changed tack and decided to go with this banner thingy now.
The point though, is it should still be easy to dismiss the notice and it's obviously sticking for some people, so I'll revert to a previous version tonight if they don't provide a fix today. :thumbsup:
EltonFrog
EltonFrog
It is being generate from the Tapatalk add-on that is installed here, on the CC server - which is generating the prompt on your device. Once they fix it and I update the add-on on the CC server it should remove the notice.
It used to be a simply browser-based popup notification and when you clicked "Cancel" it went away and stopped pestering you, buy they've obviously changed tack and decided to go with this banner thingy now.
The point though, is it should still be easy to dismiss the notice and it's obviously sticking for some people.
I'll revert tonight if they don't provide a fix today. :thumbsup:
Thanks Shaun, It might be worth noting that the "View" option does not work either.
Shaun
Founder
I think it's an overlay image that isn't disappearing like it should - the trigger to hide it obviously isn't working for some devices/platforms.
I can't do anything at the moment but will sort tonight. :thumbsup:
EltonFrog
EltonFrog
Another thing I have notice today with that banners is that when you go to different threads on the site ipthe banners goes to the middle of the page stays there for about second then goes back to the top, I've also notices that the display is jerky and pages take longer to load.
Shaun
Founder
I've uploaded a modified file that properly reports the version number back to Tapatalk but not sure if they've tweaked anything else in the process (they've not responded to the support thread I posted in).
Could one or more of you who are experiencing this problem check it now for me please and if it's still playing up I'll overwrite it with the previous working version.
Thanks,
Shaun :biggrin:
albion
Gateshead
Wasn't there some change of requirements at Apple, helping encouraging app developers to use the Apple ad system?
edit - skip that. I see now it is a web advert, not an app advert.
