mickle
innit
- 53.933606, -1.076131
Rim wreckers.
Is that a 'niche' website, you've discovered?Rim wreckers.
Why so? What do they do to the rims?Rim wreckers.
Was speaking to a friend of mine on my commute home last night. He has ordered a pair.
Are they some kind of foam, ie with bubbles containing gas, in which case won't they gradually go flat as it were?
If they really are solid rubber, I can't see how the can keep the weight down.
I don't think the price is too out of order compared to good quality mainstream tyres (double maybe, and will likely come down) - providing of course they are adequately grippy and not unduly hard work to pedal
Agree with this, if you think of the price of M+ plus 2 tubes then the price difference for complete peace of mind seems pretty good.I don't think the price is too out of order
This is assuming they do actually grip the road and last as long as they claim.
That's not really the way most foams work; your settee almost certainly has foam cushion and they won't inflate. The air is injected into a polypropylene (or whatever) sitting in a mold and the air is used to expand the foam while it's setting. I'm simplifying hugely, but hopefully this helps![]()
Ah, that kind of makes sense, though I guess they'll go down eventually in the same way sofa cushions flatten over time. A bit worried that you can't (presumably) tailor the "pressure" as you would on a normal tyre. One person might want 110psi (equivalent) but another might want 90 say? Maybe not a problem since pressure in conventional tyres is a much about keeping snakebites at bay as optimum for riding, so the first point would be dealt with by the tyre itself.
Might give one a go when the time comes, on the back at least
I posted some a list of facts about these tyres here - http://lucky-x.com/solid-tyres-tannus-make-bold-claims/
