PpPete
- Chandler's Ford
Excuse my ignorance.
How often should I lube my bike?
What parts should I lube and how do I lube them?
What lube should I use?
Any help appreciated.
The chain is the bit that needs most frequent lubrication. How frequently depends on the type of lube you use and the conditions in which you have been riding.
So called "wet lubes" last longer on the chain but tend to attract more dirt, as do things like 3 in 1.
"Dry Lubes" pick up less dirt, but need renewing more frequently.
My personal preference is ProGold which is supposed to wash the dirt off as it lubricates. I wipe the chain down after every ride and lube (using the "mickle method") at least every 200 miles - more often if it's been ridden in the rain. It's expensive, but works well and is thin enough to also be used to drizzle a little bit down the inside of brake cables if they get sticky.
On a lot of decent quality modern bikes just about every other moving part is sealed bearings so they tend to be replaced rather than re-lubed.
Once a year take the seat post out of the frame, wipe it down, put some grease on, put it back in.
