I've never read such waffle. Who drafted that? Are their bikes made of cheese?that's an article on why they think you shouldn't electrify a Tern bike, not bikes in general.
and note this quote:
"Without that process, the resulting e-bike won't ride well. But more importantly, it's very unlikely to pass relevant safety tests. An e-bike's motor adds substantial forces, in new directions, that an acoustic bike's frame and fork weren't designed to handle. For example, adding a front hub would require a massively beefed-up fork to handle the additional stresses safely."
which suggests to me limitations of the Tern rather than bikes in general.
I have a Dahon Speed Pro sports bike - there's a certain (problematical) real-life family connection between Dahon and Tern.
I definitely wouldn't try to electrify my Speed Pro - that would be a safety issue I think. Not to mention endangering my mental health.
and another quick scan of that "article".
This:
First off, there are the costs of getting your after-market motor and battery working reliably. Think fried sensors, melting wires, adapters, and other extra parts … it may cost more than you think to get your e-bike project off the ground.
Next, there are the increased maintenance costs associated with electrifying an acoustic bike. Your bike will be heavier, and your average speed will be higher, so you’ll be putting lots of extra wear and tear on your bike’s frame, fork, and components—none of which were designed to withstand that kind of use. In particular, your bike’s brakes and tires are likely to need very frequent maintenance or replacements (that’s if your tires aren’t constantly deflating on your ride).
so your tyres will go down?
whatever next - you'll break out in spots, your wee will turn blue?
Speed and decelerating are two different issues. A motor kit and battery add about 5-8kg. Riders weights could be 20-30kg in difference, the forces associated with rider weight are far greater than a motor kit.
