Cycling is great for losing weight providing you combine it with a good diet.
Sitting in an armchair reading the Daily Mirror is great for weight loss if the diet's good. Burn more than you consume, you will lose weight.
That's an amazing achievement. No-one can take away from you the sense of success and pride you must have.
Granted, you chose to be a cyclist and we all commend you for your choice, but knowing the science and the math, I wouldn't pin the rosette on the bicycle as the major contributor. I would have to pin the gold rosette on the kitchen scales.
BTW, Your blog 'Goals' has walking, running and benchpress included. Walking is about the same intensity as cycling and running is four times as calorific expensive as cycling ie a 5 mile run is equivalent of 20 miles on a bike.
Also, to get to a 100 kg bench press, there must have been a lot of reps at lesser weights. Remember lifting 1kg for a distance of 1 metre in 1 second is 1 Joule. How many Joules left your body lifting all that iron?![]()
LOL Fair enough mate, but these are things I did as a "one off" 1 month in the Gym, in addition to cycling, 1 months worth of 1 hour sessions in the Gym in the morning, wouldnt produce the results cycling has produced :-)
Oh, and back to the original question, I've seen it writ that the fitter you are the more you sweat (efficient neural response & all that) - so well done for getting fitter! Keep it up!
