I have a Specialized Tricross Sport 2008 model. For full spec (http://www.specialized.com/gb/gb/bikes/archive/2008/tc/tricrosssporttriple#specs)
I have had this bike second hand since 2009. I use it to commute to work and to tour in Europe every summer.I only ever use the drops when at speed so I can brake.
I want to put butterfly handlebars on. I know this entails some fundamental changes and I am after some pointers. I am totally confused of what is compatible. For example do I have mountain bike gearing so road bike components will not work etc I am hoping to buy the correct parts from ebay and get my LBS to install them. I have only ever changed the cassette and brake pads.
Gears & Brakes
Can I put v brakes or mini v brakes on this frame? I know I’ll need the full shebang as I currently have STI. What do I need to be aware of in terms of what kind or brakes will fit the bike.
I am using STI shifters for the gears so I know they will have go. I was looking at putting those thumb shifters on. Do I need to change the front derailleur or rear derailleur?
As it currently stands, I need a new crank set as its all worn down. I need a new cassette as that is worn down, chain as they go hand in hand.
As I need to renew these devices, now is a good time to take on a project like this as I will be spending money anyway but because I am buying from ebay I need to know I am getting the correct components.
Thanks
Gears & Brakes
Thanks
