country joe
- Caledonia
When should you change from your winters bike to your summers?
jayce said:yes you could do that but i ride a carbon framed bike the salt on the road would kill it
Pottsy said:Actually I remember someone posting on a similar thread a while back and his argument was just use your 'summer' or good bike all the time. The cost of a winter bike could be used on the slight increase of replacements required through all year usage. Plus you get the enjoyment of the good bike more often, perhaps increased familiarity with it and save on storage space of course as you have one bike less. This all seems to make good sense to me.
Only downfall I can see is the potential requirement for mudguards in winter which your summer bike might not have fittings/space for.
Just another view on the subject.
i used a carbon bike all year and with salt, grit and all sorts on the road after a while it looked like shoot it started peeling and lost its shine so dont tell me that grit and salt dont effect carbon it effects everything on a bikeChris James said:Mmm. Salt damaging carbon fibre? Perhaps you would care to give a scientific explanation as to precisely how this damage woudl occur?
I would be more worried about all the aluminium alloy parts on your bike due to localised corrosion, general corrosion of the chain (pretty easy to keep in check, using wet lube) and the erosive effects on your rims of grit from the road.
