Sturmey Archer drop bar shifters
buddha
My twistgrip shifter has finally died (good riddance, the nasty plastic thing that it was!). It was mounted on the tops, near the stem. Which took the use of a saw and some solvent to fit, probably hastening it's demise.
Ideally, I'd like a thumb operated shifter nearer the hoods. But see that the 5sp thumb shifter looks a bit weak.
Do the newer SA 5-speed shifters (SLS50-T for example) only work with wide ratio hubs? Or can they be 'adapted' to work for normal/older ratio ones? Or is there something else out there? (nothing expensive mind, as this like is likely to get chained up outside a sarf-London Lidl).
Zoiders
According to Sturmey they currently turn out a 3 speed version of the thumbshifter, a bar end fitted conversion and it's also possible to bolt the shiftfer straight onto a braze or band on so you have all 3 options.
buddha
buddha
I've just had another look of the sturmey site. Problem is, for 5 speed, they are all for the post 2009 'wide' ratio hubs.
Do these hubs need a different amount of cable-pull, or is it something more than that?
buddha
buddha
Call me a noob, but what's wrong with just using a bar end friction shifter?
Maybe nothing. But (I think/have heard) that the indexing is pretty crucial. If it's not spot-on it won't shift and/or will mangle something.
Smut Pedaller
London
yep spot on, you definitely want the proper indexed shifter for hub gears. Not sure about cable pull, but I would hazard a guess that all the late model ones would probably be the same.
fixedfixer
Could try here http://www.tritoncycles.co.uk/m13b0s108p0/Components/Gears_-_Shifters some of these look good for either bar end or the lever type that work with 3 speed.
