Stuck with punctur
Andywinds
I'm stuck with a puncture, found a pot hole. I've only got one tire leaver. For the life of me cannot get tire off. Am I doing something wrong?
13 rider
leicester
You need more tyres levers two or three .search you tube for GCN how to change a tyre watching it will be better than me trying to describe it
Mo1959
Unless it is an especially easy to remove tyre, I find you need at least two tyre levers. Nothing else lying around that you could improvise to hold the bead out until you put the lever back in again along the tyre a bit?
Andywinds
Andywinds
Home now, slight bump in the ride, I think the tire did not seat properly. I've also scratched the rim so when I brake it catches. Oh what fun!
Mo1959
Andywinds
Andywinds
Was it a metal tyre lever? I like these, and less chance of scratching the rim being plastic.
http://www.ebay.co.uk/itm/Schwalbe-...459723?hash=item5d5edc618b:g:~fMAAOSwpDdVds~N
You could probably gently sand down the scrape on the rim to get it smooth again.
Yes it was, it also looks like when I put the tire back on I got the inner tube caught! It looks like the tire is out of shape.
Andywinds
Andywinds
I would think a fine grade emery paper would be fine.
Looks like I've punctured the second inner tube! It would have been when I used the metal levers! I never had a problem in the past with my MTB, but then I was able to remove a tire without levers! lol
