fatboy123cycling
- Wirral
If it was mine I would use a hacksaw to saw the nut completely in half - you could melt the nylon nut with heat - but that would damage the paintwork.
Use a hacksaw to make a slot in the bolt head. Then use a big flat screwdriver to hold it whilst you wrangle the nut off.
^ this x1000 - get an Irwin nut remover on the nut and turn... it'll come off in secondsI use Irwin Bolt/Nut removers on rounded off nuts n bolts........with your nut being in reasonable shape maybe a suitable Irwin would fit the coachbolt and remove it that way.....replace with a new nut & bolt....
