bigjim said:
What a shame you have to use such an agressive and rude tone in order to attempt to get your message across but I suppose it is a sign of the times.
It's not a sign of anything other than the way I personally communicate my opinions. The "times" and place I was born is early 50s in the Midlands and, as someone else here correctly noted, that's where I get my straightforward manner. If you find my manner aggressive and rude ... that's more due to the fact that I called you out on the inconsistency of your thesis. Understandably your feathers got ruffled.
I still stand by my assertion that your post makes no sense and rather it is your opinion that the OP needn't change anything that is unhelpful. And the experience and gear you are basing that on is irrelevant, because it also does not appear to be right for climbing hills.
Again, if one has the correct gearing for the job, there is no need to walk a bike. I have walked a bike on one occasion. That was on a long 21% grade on loose gravel with a heavily loaded touring rig. I really should have had something lower than the 21" gear the bike came stock with.
To repeat the obvious: I don't want to walk on a bike ride. I want to ride. I go for quiet walks along the beach at the end of the street when I want to do so.
The only people I ever (rarely) see walking their bikes uphill are those who are obviously unfit and/or ... have gears unmatched to the terrain.
Finally, you are the irritable poster, because you can't admit that your "advice" was bogus and leave it at that.
