Stripped pannier frame mount rivet nuts, pulled it out, what next?
Ev0d3vil
Is it easy to install a new rivet nut back so that I can mount my pannier side arms?
Domus
Sunny Radcliffe
I would suggest going next size up and using a good rivnut tool, if not next size up, then same size with added epoxy. Good luck
Big John
Yes it is easy providing you have the kit. May be worth taking a look around YouTube. There are home grown ways of installing a rivnut but a basic proper tool doesn't cost the earth and you never know when you'll need it again. I've toyed with getting one for some bottle cage rivnuts that need replacing but not actually plucked up courage to part with the money. There are many DIY methods out there but I'm a firm believer in using a proper tool for the job (doesn't have to be a Park Tool!). Good luck.
London
Got to say this is ONE reason I don't like ally frames (I have had rivnut issues)
I wouldn't want any rack of mine to depend on a rivnut fixing - I often put a lot of weight on my racks.
silva
Belgium
What about tying the ends together on the position they are on the picture (so within the frame triangle just under the seat tube), then some trousers belts, wrapped as much as their length allows, diagonally around the frame tubes joint there? It will even be stronger, only somewhat less stiff.
The entire luggage backside of my bikes frame (see my avatar) is held together by that.
Benefit is, if it all suffers a hit, it can move a bit to absorb the energy instead of breaking.
Something important: make sure the movement can't cause fretting in the frame. Inner tube rubber is ideally to prevent, it can absorb energy itself too, is antislip, and allows a tight knot.
Here, 40 kg loaded on top of such belts-connected pannier frame.
When such heavy loads, I connect the rear wheel frame tubes additionally, in order to offload the pannier frame bolts abit.
565106
By the way, how did it break? It's not that they're that weak, and actually, they don't have to take the luggage load, only the horizontal component of it which is much smaller since bicycles speed changes are not that big eh.
