Strava - alternatives etc
Hi all,
I use Strava when I ride my bike and when I go for a walk
I do it for 2 reasons
a) to log my rides out of interest and to see where I have been (sometime because when I get back I have no clue where on Earth I actually went at some points on the ride!)
b) so my wife can see where I am if she needs to know for some reason - e.g. if she gets worried for some reason or if something changes and she needs to know if I will be back soon or does she need to ring and tell me I need to come back
Anyway - so I use the free version which include a thing where you can send a message to someone and they can then see where you are
But - recently at times it seems to be telling her that I am some distance away - then I walk through the front, in spite of the 4g and 5G signals being OK for quite a lot of the nearby route so it should have updated OK
Also - I tend to prefer to avoid the normal market leader and use smaller players
But I don;t know of any that do both - but then I could use a possibly more accurate tracking app AND something different for the tracking
anyone got any experiences
Supersuperleeds
Leicester
If you both have smartphones you can have tracking apps that let you both know were the other is.
lostinthought
I ditched Strava a few years ago, and since getting a Garmin, I now use Garmin Connect to plan and keep track of rides. I'm pretty sure it's free to use, and you can import rides from anywhere. It's clunkier than Strava, and there isn't much of a social aspect to it (not my thing, but you never know). The route planner works pretty well, however, and the stats and charts are tolerably well done.
There certainly was a live-tracking feature, but I found it fiddly to set up and unreliable. I'd guess it also requires a Gamin device. If you both have iPhones/other apple devices, you can easily use "Find My" to keep track of each other. I bet there's an android equivalent.
E
Z’ha’dum
Funnily enough my wife has only rung me once when I have been out riding
It was about the only time I had stopped and got talking to a good looking woman!!!!!
turned out that the GPS on my phone had decided to stop working after about 2-3 miles and kept supplying the same location to Strava
After a while - quite a long time but whatever - the system decided to send her an alert saying that I had not moved for a long time
so she rang to check I was OK
which was weird
(Note - either that or she is WAY better at computery stuff than I think and managed to hack the route so that it appeared that I was stationary for 45 minutes then started again when I stopped and restarted GPS on my phone
What is also weird is that if I accidentally forget to stop STrava when I get home and leave it switched on in my coat pocket then clearly it also does not move for a long time
However, inb this case it never sends an alert to her phone
and of I look at it after it shows me a moving around alot - just in a very small area as the GPS error varied
so as an alert system it is probably a bit rubbish as the GPS signal needs to be exactly the same for a long time - whereas it varies even if you are stationary
Bristolian
Bristol, UK
If you have WhatsApp on your mobile phones you can send your live location to each other for up to 8 hours. This is free and, so far, has proven to be accurate (as accurate as the phone's gps anyway).
I use this when I go out for a ride on the bike and also whenever I head off on a photography jaunt (in the car), particularly if I'm going on my own. I just go back into WhatsApp when I get home and cancel the feature to stop it.
