Fiona N
- you can also get coloured ones to match the bike! (If you are really obsessive).
Hey - watch who you're calling obsessive
An alternative is to use 2.5mm shrink wrap electrical cable cover (Maplins etc.). It's not as good as cable crimp caps but it doesn't mess up the cable end so that you can remove it without fraying or cutting the end. Still leaves the risk of spearing yourself or somebody else with the cable end though
Another is to use wire terminal block (the sort to connect wires via two small screws) .. removed the plastic block covering and feed the single connector over the cable and loop the end back into the connector and tighten the two screws.
I have - it hurts!Never have been speared by the loose ends
Here you go...Sorry - it didn't seem to be used on this forum.
If you want to bring you forum avatars in to synch and use it on this site then I'll change mine as you've been here the longest.
