Stoping cables fraying
Chris S
Birmingham
I fitted a new gear cable yesterday and it's already unraveling at the cut end.
Are you supposed to do something to stop this happening?
Cheule
Coventry
Yes - get some of these and crimp on - job done! :biggrin:
L.E.D.
Super glue also works but as Colin has pointed out Cable ends stop the painful incidents that can occur.
dodgy
I usually have some super glue to hand (not literally) so dab a bit on and put an end stop on, too.
But really, I'm surprised to read that anyone thought some kind of cable end treatment is optional!
Talking about cable ends the back brake cable on my hybrid is sticking a bit so I popped into a lbs to a) get a new cable, and b) to escape the torrential weather; I forgot to buy cable ends, doh :blush:
MartinC
Cheltenham
An alternative is to use 2.5mm shrink wrap electrical cable cover (Maplins etc.). It's not as good as cable crimp caps but it doesn't mess up the cable end so that you can remove it without fraying or cutting the end. Still leaves the risk of spearing yourself or somebody else with the cable end though
NormanD
Lunatic Asylum Escapee
If you can't find crimps then below should freely available in any DIY store
One trick is to use pot rivet heads ... just place the pliers over the rivet and tap it on a hard surface so the rivet head comes free of the pin and crimp that over the cable end.
Another is to use wire terminal block (the sort to connect wires via two small screws) .. removed the plastic block covering and feed the single connector over the cable and loop the end back into the connector and tighten the two screws.
Hope they help
Norm
