Tin Pot
I seem to be suffering this on two bikes now, fixed the first by replacing the entire brake caliper.
The one I'm complaining about now is new though, TRP rear brake for Argon18. It's a weird caliper on the underside of the chainstays. Internal cabling, through a steel bend that hold the calipers together. A bit like this:
It had a new gear cable, but I've replaced it partly to see if it fixed this, partly because it was already fraying.
I've played with all the screws I can, but the only effect is to clamp the wheel tighter. I have to push the right brake out to 'reset' it.
It seems to be the right brake pad primarily but neither release. The right brake pad holder has a screw that levers the pad closer or further from the rim. And another screw I can't figure out what it does.
I'm down to thinking it's the cable sticking somewhere, but I've straightened the cabling and the spring functions on the brake arms it just doesn't seem to be strong enough.
Any ideas?
Any ideas?
