Collisions? I don't think so.
Oh dear, hopefully the OP will consult the link to Sheldon rather than accept the misinformation found on forums.
I think you've misread that. The "collisions" you refer to are mentioned as "impacts" that take place in the Brinell hardness test. If you read the article properly, you'll see that TBW mentions that this doesn't actually happen, rather that lubricant breakdown is taking place instead.The pitting can also be caused by collisions. There is a partial solution on Sheldon, especially if the bearings have 'caged' balls. This is to remove the cage and repack the bearing with loose balls, so that they will no longer automatically match up with the dents in the races. I've managed to do this with the 'sealed' cartridge bearings in my integrated headset.
I have now got some new cartridges (cane creek from Chain reaction) but will first need to remove the bottom race of the lower cartridge which has corroded onto the fork. I think some delicate hacksawing will be required.
Sheldon saysI think you've misread that. The "collisions" you refer to are mentioned as "impacts" that take place in the Brinell hardness test. If you read the article properly, you'll see that TBW mentions that this doesn't actually happen, rather that lubricant breakdown is taking place instead.
That is something I hadnt considered...I had assumed it should tighten it as far as I could without breaking the thread?...
should one lubricate ones headset then?
Advice is either right or wrong. The method of its delivery irrelevant.Oh dear, hopefully the OP will consult the link to Sheldon rather than accept the misinformation found on forums.
