Steep Hill Gears.
Pontefract
It looks to be about 28, just had a quick look on the sheet at wiggle and that cassette if the same is 28, which will give you a ratio of 1:1.25, there are cassette (but i dont know what would fit no experience of your drive train) upto 36 teeth will give you 1:1 which is pretty low, I dont generally use less than 1:1.36 unless I run out of steam (mind I do that a few times), but then i have a triple with a low 26th so I can knock it down a little further if need be.
Boon 51
Boon 51
Deal. Kent.
It will be marked on each cog on the cassette, looks pretty clean so just look carefully for the marking.
Can't see any nunbers but just counted and its 28 teeth.. on the biggest rear cog.
Boon 51
Boon 51
Deal. Kent.
What you need is a 24 inch gear to get you up the steep hills. aka two feet. ;)
Seriously though it doesn't take long on hill climbing before they get a lot easier as your body adapts so unless you really can't get up them at all I would leave off changing stuff around as you might well be changing it back in a few weeks time. And if you can't get up a hill, go as far as you can and then walk or stop and rest before carrying on. And next time aim to go a bit further before you get off and fairly soon you won't be getting off at all unless its Mont Ventoux
I cant get off the bike... if I do that then I will be defeated.
I am new to road biking but as you say it will get easier as time goes on, hence the change of cogs to keep me working hard.. we are of course on a 1700m mountain and this is a flat as it gets..
youngoldbloke
'They will be using 37 by 28 - and that's a tiny gear ......' or words to that effect - during the commentary on the Vuelta yesterday, as Contador, Rodriguez, Valverde and co were riding up 18 - 23 % - if they can do it why not you?:biggrin:
"Never give up, never surrender"
- Galaxy Quest
Boon 51
Boon 51
Deal. Kent.
I watched it yesterday too, and I did hear someone say Contador's bike wasn't geared right.. but yes I would like to do it too if I was years younger.. :biggrin: but I'm the wrong side of twenty by years.
PS. On the picture I just posted on this thread with the mountain top over looking our village there is a tale...... Just on the other side there is a 40 km bit of road with a hill climb that they used on the Vuelta 2 years ago and its still got all the writing on the road as you near the top.. stunning..
Boon 51
Boon 51
Deal. Kent.
- Galaxy Quest
I thoughts exactly... :smile:
Mandy jo
Regular
ok, I'm confused! I have a chainset of 30/39/50 and a cassette of 12-28. I got the triple as I'm struggling with hills due to knee surgery, any advice appreciated!
Pontefract
Your inner chain ring the 30 you could change to a 28 or possible 26, you will need to find what B.C.D. (Bolt centre Diameter) its a bit awkward to measure, so measure edge bolt to edge bolt or centr to centre Shelden explains better than I do. The BCD is usually 74mm for the inner (mine was odd so I had to get a new chainset).
Your current set up of 30 front 28 back gives you a ratio of 1;1.07 if you change to a 28 front it gives you a 1:1 ratio and a 26 1:0.93 which is pretty low you can go lower by changing the rear cassette for something with either 32 or 34 teeth the 34 giving you a really low ratio of 1:0.76, I found this to low though it will get you up anything just about though.
But you need to make sure your rear mech can cope with 34, some cant my sora couldnt so I changed it for an acera, when I am better I will probably revert to more road oriented gears, though my next project is to convert from 7 to 8 gears then I can go 13-15-17-19-21-24-28-34 or 13-15-17-19-21-23-26-30 and up the inner ring from the current 26 to maybe 28.
In all situations you will need to check that both front and back derailleur's can travel over the required number of teeth, i.e. the front 14 teeth if you change to a 26, it should do 12 if you go to 28.
Since your back is already 28 (12-28 = 16th) it probably will do 32 or possible 34, so your total max difference would be 26-50 on the front = 24 and 12-34 =22 on the back giving you a total of 46 which I think is getting a little much, but I am not very sure on all the specifications on all modern stuff.
Boon 51
Boon 51
Deal. Kent.
Hi Nigel.
I have got to take the bike in for its first service at the end of the week so I will get my Trudi who's Spanish is better than mine to tell him the problem and see if they might change it as the bike is still new.. you never know, they might just surprise me..
Pontefract
Hi Nigel.
They might, depends how friendly they are I suppose.
