steel frame bikes
Bonefish Blues
Banging donk
52 Festive Road
I went towards the Spa and the Kona as each comes with (will be fitted with on request in the case of the Spa) bar end shifters.
I think Swinnertons might do that too, having a proper shop and a good reputation for service.
SkipdiverJohn
Deplorable Brexiteer
London
LHT almost level top tube though which might bother some - it does me but personal preference.
Personally I think combining drop bars with a sloping top tube mens frame is just wrong.:headshake:
My tolerance for sloping top tubes is limited solely to flat bar hybrids and MTB's - and even then only if the amount of slope is no more than a few degrees. I would not give shed room to any drop bar road racing/touring frame whose top tube was anything but perfectly level. xx(
London
:smile:
ah well you are even more of a traditionalist than me skipdiver.
Tis true I am a flat bar person.
My preference for sloping is practical rather than aesthetic.
All personal of course but I think it is a factor the OP should give some thought to - and then decide whatever or even decide that it is irrelevant.
ride on skipdiver, all the best
Cuchilo
Prize winning member X2
London
you dont fancy a go on this when ive finished it then ?
London
View attachment 455833 [
well it certainly doesn't fit with what the OP is looking for.
SkipdiverJohn
London
No, I'll pass up on your kind offer thanks!
To me that's wrong on so many levels; oversized tubes, rear stays not joining the main triangle at the seatpost clamp, too much seatpost sticking out, bars way too low. The only thing I do like if I'm honest is the fact you've got rim brakes not discs - as I don't like discs either!
Essentially, pretty much anything that might be found built into or fitted to a modern bike, I wouldn't have on any of mine. Since steel frames don't wear out, no need to ever buy a new bike, all I need to do is carry on riding old steel frames and just replace any worn mechanicals.
London
too much seatpost sticking out, .
On topic with bygonera's initial post, a certain amount of exposed seatpost can be handy on a bike used for loaded touring skipdiver.
Especially if you pack (some would say overpack) like me with dry bags/tents/kitchen sinks on top of the rack - gives the whole motley collection something to rest/cuddle up against and helps with bungeeing. A short exposed seat-tube could cause problems - the whole load of junk could be trying to shove your arse forward off the saddle.
all the best
SkipdiverJohn
London
No doubt you are right about that, but the most I ever carry on a rear rack is a few items of shopping placed inside a plastic greengrocer's produce basket held on with cable ties. Sometimes I might have a small Lidl cycling rucksack on my back instead, but that's as much load as I carry by bike. I just much prefer the appearance of full-size classic steel frames with horizontal top tubes and only a minimum amount of seatpost out. When I see 8 or 9 inches or more of seatpost on view, I'm inclined to think the owner should have got a bigger frame!
raleighnut
So you wouldn't be a fan of this then John.
BTW that seatpost doesn't go any lower, I had it custom made.
